Export CyberArk Data via SCIM
This guide shows how to set up a SCIM connector to extract data from your CyberArk instance into CSV source files that will in turn be fed to the Upward Data Synchronization task and to your Identity Manager resource repository. It will focus on registering Identity Manager within the target CyberArk instance, configuring the connector, and building the job to perform regularly scheduled synchronization.
Prerequisites
External system configuration
Usually CyberArk provides the environment to use AAM (Application Access Manager) and SCIM (System for Cross-domain Identity Management). For example, PrivateArk Server, PrivateArk and other tools can be found on a VM-based environment.
It is strongly recommended that you follow the official CyberArk SCIM Server Implementation Guide (the CyberArk team can provide this document) in order to set up the environment. When you've completed the installation or if CyberArk has already installed it, you can verify the installation:
Log into PrivateArk Client, locate and open the SCIM Config safe.
Check the presence of the following objects:
Encryption-key
: The SCIM Server uses a local cache to store objects retrieved from the Vault. Although no credentials (other than the ones in the SCIM Config safe, which are not stored on the cache) are retrieved, we encrypt the cache with this encryption key. The key is randomly generated, and not exposed by the installer, but can be changed if desired.GlobalConfig.yml
: This is the configuration file for the overall SCIM server settings. It is responsible for the setting of performance parameters and additional added features.Usercube-account
: This is a privileged account to allow Identity Manager to authenticate its REST API requests to the SCIM Server. The password for this account must be the same as the Identity Manager-user (Identity Manager can be replaced by any other name like Client).SCIM-account
: This is a privileged account, managed by the Central Policy Manager (CPM is the module of the PAM tool that is responsible for managing the passwords and any policies/exceptions configured), which allows the SCIM server to retrieve the password for SCIM-user through an Application Identity Manager (AIM) Credential Provider call.
Verify that the following Users were created in the PrivateArk Client:
Go to Tools > Administrative Tools.
Select Users and Groups.
Ensure the following users have been created:
SCIM-user
: This is a CyberArk user with full privileges for creating and managing Safes, Accounts, Permissions, and Users. This user is required by the CyberArk's Command Line Interface (PACLI, used to perform quick Vault-level functions without logging in to the PrivateArk client) on the SCIM server for logging into the Vault and managing objects on behalf of client applications such as Identity Manager.Client-user
: This is a CyberArk user for authenticating requests made to the SCIM server using the REST API. (The name Client-user' can change and be replaced by Identity Manager-user' for example.)
Now we can consider that the installation is correct, the login is
Usercube-user
and the passwordCyberArk1
Identity Manager configuration
This step sets up the Identity Manager Agent to use the SCIM connector and access the CyberArk data.
The settings must be entered in the appsettings.agent > Connections section. See the SCIM topic for additional information.
Connect to the target CyberArk instance
In the Connections
section, add one new subsection that will contain the credentials for the
target CyberArk. Use a meaningful name to remember which CyberArk is accessed via this section.
This example connects via the
SCIMCyberArkExport
connection to the CyberArk system:
appsettings.agent.json
{ ... "Connections": { ... "SCIMCyberArkExport": { ... } } }
Input credentials
- The Server attribute with the CyberArk's address. It has the form:
https://host:port/CyberArk/scim
. - The Login attribute with the User's login value (in our example,
Usercube-user
). - The Password attribute with the User's login value (in our example,
Cyberark1
For example:
{ ... "Connections": { ... "SCIMCyberArkExport": { "Server": "https://host:port/CyberArk/scim",
"Login": "Usercube-user", "Password": "Cyberark1" } } }
For pedagogical reasons, this guide focuses on the simplest way to set up the export, but it's not
the most secure. Hence it is strongly recommended that you protect credentials using Azure Key Vault
or CyberArk in a production environment.
Netwrix Identity Manager (formerly Usercube)recommends completing this guide once, testing the
configuration, and only then, switching to a more secure way of storing credentials.
Set exported objects, exported attributes and export files
This step focuses on choosing and setting up the list of SCIM objects and attributes to be exported.
The Filter attribute defines what is exported. It is located in the
appsettings.agent > Connections > SCIMCyberArkExport
subsection previously created.
Choose objects to export
The list of objects to export depends on the Role Model requirements. The list will evolve iteratively as the project's needs become clearer.
The SCIM entities available in a CyberArk implementation are:
- Users: CyberArk Users.
- Containers: Containers/CyberArk Safes.
- ContainerPermissions: Permissions on CyberArk Safes.
- Privileged Data: Privileged Data/CyberArk Accounts.
- Groups: CyberArk Groups.
Filters are defined in the next part.
Filtering
An exhaustive list of entities and attributes provided by CyberArk is available in their
technical documentation
or the SCIM Swagger UI
The Filter
and FilterGroup
setting syntax is detailed in the
SCIM optional attributes.
SCIMSyntax
must also be set to CyberArk
because the CyberArk system doesn't strictly follow all
the SCIM rules at the moment.
Example
The following example sets up the Users, ContainerPermissions, Containers and Groups for export.
For Users, we give an example for each type of attribute:
- userName is an attribute of the base schema.
- ldapFullDN is an attribute of the
urn:ietf:params:scim:schemas:cyberark:1.0:User
schema because it is separated by:
. - givenName is a sub-attribute of the attribute
name
Notice the *
that separates the entities.
"Login": "Usercube-user", "Password": "Cyberark1", "Filter":
"Users;urn:ietf:params:scim:schemas:cyberark:1.0:User:ldapFullDN|ldapDirectory id userName active
name:givenName|middleName|familyName emails:value phoneNumbers:value title profileUrl source
nativeIdentifier*ContainerPermissions;id user:value group:value container:value rights*Containers;id
displayName type name", "FilterGroup": "Groups;id displayName", "SCIMSyntax": "CyberArk" } } }
Set up export files
The export generates CSV source files that will be fed to the Upward Data Synchronization task.
The SCIM connector generates one file per entity, the name is generated as: EntryFile
+ '_'
+ FilterEntity
or MembersFile
+ '_'
+ FilterGroupEntity
Moreover, SyncCookiesFile
can be specified to indicate the location of the cookie file for an incremental export.
See the SCIMtopic for additional information.
The target directory and file name are chosen freely. However, Netwrix Identity Manager (formerly Usercube) strongly recommends using the
Create a Working Directory
Temp/ExportOutput
folder and choosing file names that start with the CyberArk_
prefix.
Example
With the following example, the resulting files are:
C:/UsercubeDemo/Temp/ExportOutput/CyberArk_Users.csv
C:/UsercubeDemo/Temp/ExportOutput/CyberArk_ContainerPermissions.csv
C:/UsercubeDemo/Temp/ExportOutput/CyberArk_Containers.csv
C:/UsercubeDemo/Temp/ExportOutput/CyberArk_members_Groups.csv
appsettings.agent.json { ... "Connections": { ... "SCIMCyberArkExport": { "Server":
"https://host:port/CyberArk/scim", "Login": "Usercube-user", "Password": "Cyberark1", "Filter":
displayName type name", "FilterGroup": "Groups;id displayName", "EntryFile":
"C:/UsercubeDemo/Temp/ExportOutput/CyberArk", "MembersFile":
"C:/UsercubeDemo/Temp/ExportOutput/CyberArk_members", "SCIMSyntax": "CyberArk" } } }
Every file contains the data as CSV, with one column per attribute.
Build the Connector
Declare a connector
To be used for export tasks, a connector must be declared in the Toolkit for XML Configuration and linked to an Agent.
It is strongly recommended that the applicative configuration be stored the
Conf
folder as a set of xml
files organized by connector.
In the
Conf
folder, create aSCIMCyberArk
directory. -
In the
SCIMCyberArk
directory create aCyberArk Connector.xml
file.This file contains the declaration of the connector and the associated Entity Model.
Use the Connector element to declare the connector with the following attributes:
- Identifier identifies this connector in the Toolkit for XML Configuration. We recommend using a meaningful name such as
CyberArk
. If several connections to several CyberArk targets are possible, only one CyberArk Connector per Agent is used. - DisplayName_Li, i ? [1..16] are used in the UI.
- Agent is the identifier of the Agent that will run this connector's export task. The Agent's identifier can be found in the agent's appsettings.agent > OpenId > AgentIdentifier.
Don't forget the
<?xml>
and<ConfigurationFile>
elements (see example below).
This example declares the
CyberArk
connector on theLocal
agent:
Conf/SCIMCyberArk/CyberArk Connector.xml
<Connector Identifier="CyberArk" DisplayName_L1="CyberArk" Agent="Local" /> <Connection Identifier="SCIMCyberArkExport" Connector="CyberArk" DisplayName_L1="CyberArk" Package="Usercube.SCIM.CyberArk@0000001" /> ...
</ConfigurationFile>
Build the entity model
The exported data to be written to the Identity Management must be aligned with the Entity Model.
The Entity Model should match as closely as possible the structure of the CyberArk data relevant for Identity Manager. It is designed by analyzing the CyberArk data structure, and describing said data with the Entity Model and Entity Association. Eventually, it is up to the integration team to design the Entity Model that best serves the Assignment Policy needs. It will most likely be refined iteratively throughout the project integration.
A good starting point for the Entity Model is to mirror the shape of the exported CyberArk SCIM objects. This guide provides a few examples that can serve this purpose. Thus, CyberArk SCIM objects such as Users and Groups can be described by Assignment Policy, and group membership by Entity Association.
The Entity Model for the CyberArk connector is written in the Toolkit for XML Configuration. It is strongly recommended to write the entity model to the newly created Conf/SCIMCyberArk/CyberArk Connector.xml
file.
Write entity types
Declaring an Assignment Policy is achieved with the <EntityType>
tag and the following attributes:
- Identifier is the entity type's name. It must be unique among the entity types. It is strongly recommended to prefix this name with the connector's name. An example for CyberArk is
CyberArk_User
. - DisplayName_Li, i ? [1..16] are used in the UI to identify this Assignment Policy for the end-user. DisplayName_L1 is the name of the entity type in language number one. If this language is English, a good example value would be
CyberArk - User
Example
Conf/SCIMCyberArk/CyberArk Connector.xml ...
<EntityType Identifier="CyberArk_User" DisplayName_L1="CyberArk - User"> ... </EntityType>...
The CyberArk SCIM objects attributes are modeled by Assignment Policyproperties, with the <Property>
tags declared as children of the <EntityType>
Remember that there are several kinds of by Assignment Policy (determined by the TargetColumnIndex
): scalar and navigation.
- Scalar properties can be defined to represent scalar attributes such as
userName
,active
orgivenName
. - Navigation properties represent associations such as group memberships.
Finally, the main attributes of the <Property>
tag are the following:
- Identifier identifies the property with a mandatory unique name. It must be unique among the entity properties for this entity type.
- Type defines the type of property. A scalar property type can be:
String
,Bytes
,Int16
,Int32
,Int64
,DateTime
,Bool
,Guid
,Double
,Binary
,Byte
, orOption
. The navigation property type isForeignKey
. - TargetColumnIndex defines in which column of the resource table the property is stored. See more details at Entity Type.
Example
This example defines an entity type named CyberArk_User
to match the attributes selected for extraction from CyberArk in the previous example.
Notice the omitted TargetColumnIndex attribute and the presence of Type="ForeignKey"
for the groups
and containers
properties. If omitted, this attribute indicates that the properties are navigation properties.
<EntityType Identifier="CyberArk_User" DisplayName_L1="CyberArk User" DisplayName_L2="Compte CyberArk">
<Property Identifier="CyberArk_id" DisplayName_L1="Id" IsKey="true" TargetColumnIndex="0" Type="String" />
<Property Identifier="userName" DisplayName_L1="User Name" TargetColumnIndex="6" Type="String" />
<Property Identifier="active" DisplayName_L1="Active" TargetColumnIndex="7" Type="String" />
<Property Identifier="givenName" DisplayName_L1="First Name" TargetColumnIndex="8" Type="String" />
<Property Identifier="middleName" DisplayName_L1="Middle Name" TargetColumnIndex="9" Type="String" />
<Property Identifier="familyName" DisplayName_L1="Last Name" TargetColumnIndex="10" Type="String" />
<Property Identifier="emails" DisplayName_L1="Emails" TargetColumnIndex="11" Type="String" />
<Property Identifier="phoneNumbers" DisplayName_L1="Phone Numbers" TargetColumnIndex="12" Type="String" />
<Property Identifier="title" DisplayName_L1="Title" TargetColumnIndex="13" Type="String" />
<Property Identifier="profileUrl" DisplayName_L1="Profile Url" TargetColumnIndex="14" Type="String" />
<Property Identifier="dn" DisplayName_L1="DN" TargetColumnIndex="15" Type="String" />
<Property Identifier="source" DisplayName_L1="Source" TargetColumnIndex="16" Type="String" />
<Property Identifier="ldapFullDN" DisplayName_L1="LdapFullDN" TargetColumnIndex="17" Type="String" />
<Property Identifier="ldapDirectory" DisplayName_L1="LdapDirectory" TargetColumnIndex="18" Type="String" />
<Property Identifier="groups" DisplayName_L1="Groups" Type="ForeignKey" />
<Property Identifier="containers" DisplayName_L1="containers" Type="ForeignKey" /></EntityType>...
Write entity associations
Assignment Policy are associated through their navigation properties with Entity Association elements.
Example
The following example declares an n-n
association between a CyberArk_User
and CyberArk_Group
The groups
property of a CyberArk_User
is a collection of Group IDs (modeled as an CyberArk_Group
EntityType) of which this CyberArk_User
is a member.
The Users
property of a CyberArk_Group
is a collection of CyberArk_User
IDs which are members of this Group.
<EntityAssociation Identifier="CyberArk_Group_Members" DisplayName_L1="Group Members" IsProperty1Collection="true" Property1="CyberArk_Group:Users" IsProperty2Collection="true" Property2="CyberArk_User:groups" />...
The exact nature of the IDs are described by the associated Entity Association Mapping.
Notice the format of the Property1 and Property2 xml attributes: the name of the entity type followed by :
and the name of an entity property. It is a Binding that describes in one expression both the target entity type and property.
Create mapping
The entity type must be mapped property by property to the exported attributes of CyberArk SCIM objects (namely, the columns of the CSV source files generated by the export).
The Entity Type Mapping, Entity Association Mapping, and Entity Property Mapping elements serve this purpose.
Write the entity type mapping
The Entity Type Mapping element maps scalar properties from the CSV source file to an entity type.
<EntityTypeMapping Identifier="CyberArk_User" Connector="CyberArk" ConnectionTable="SCIMCyberArkExport_Users" >
... </EntityTypeMapping>...
To do so, the entity type mapping uses the Entity Type Mapping element with the <Property>
tag. This maps the CSV column from ConnectionColumn
to the target EntityType property which is written to the Identifier attribute.
Example
<Property Identifier="CyberArk_id" ConnectionColumn="id" IsPrimaryKey="true" />
<Property Identifier="userName" ConnectionColumn="userName" />
<Property Identifier="active" ConnectionColumn="active" />
<Property Identifier="givenName" ConnectionColumn="name:givenName" />
<Property Identifier="middleName" ConnectionColumn="name:middleName" />
<Property Identifier="familyName" ConnectionColumn="name:familyName" />
<Property Identifier="emails" ConnectionColumn="emails:value" IsMultiValuedProperty="true" />
<Property Identifier="phoneNumbers" ConnectionColumn="phoneNumbers:value" IsMultiValuedProperty="true" />
<Property Identifier="title" ConnectionColumn="title" />
<Property Identifier="profileUrl" ConnectionColumn="profileUrl" />
<Property Identifier="ldapDirectory" ConnectionColumn="ldapDirectory" />
<Property Identifier="ldapFullDN" ConnectionColumn="ldapFullDN" />
<Property Identifier="source" ConnectionColumn="source" ScimSchema="urn:ietf:params:scim:schemas:pam:1.0:LinkedObject"/>
<Property Identifier="dn" ConnectionColumn="nativeIdentifier" ScimSchema="urn:ietf:params:scim:schemas:pam:1.0:LinkedObject" />
As a result, after synchronization, the UR_Resource
table will be updated from the CSV source files data.
Let's take the example of a new CyberArk_User
which has never been synchronized. The UR_Resource
table receives a new line for which the 6th column (userName
) is filled in with the userName
column from the C:/UsercubeDemo/Temp/ExportOutput/CyberArk_Users.csv
file.
Write the entity association mapping
The Entity Association Mapping element maps navigation properties, used in Entity Association.
An Entity Association Mapping element refers to an Entity Association written to the Identifier xml attribute. Then, just as the Entity Type Mapping element, it maps columns values from a CSV source file to an EntityType property.
Example
The following example describes the actual user/group associations between CyberArk_User
and CyberArk_Group
These associations are exported from the CyberArk system into the C:/UsercubeDemo/Temp/ExportOutput/CyberArk_members_Groups.csv
file. Each line of the file associates a value (property CyberArk_id
from CyberArk_Group
) and a MemberId (property CyberArk_id
from CyberArk_User
value | MemberId |
1 | 100 |
1 | 101 |
2 | 102 |
2 | 103 |
3 | 104 |
The following Entity Association Mapping describes the mapping for the CyberArk_Group_Members
EntityAssociation:
<EntityAssociation Identifier="CyberArk_Group_Members" DisplayName_L1="Group Members" IsProperty1Collection="true" Property1="CyberArk_Group:Users" IsProperty2Collection="true" Property2="CyberArk_User:groups" /><EntityAssociationMapping Identifier="CyberArk_Group_Members" Column1="value" EntityPropertyMapping1="CyberArk_Group:CyberArk_id" Column2="MemberId" EntityPropertyMapping2="CyberArk_User:CyberArk_id" Connector="CyberArk" ConnectionTable="SCIMCyberArkExport_members_Groups" />...
Here are a few explanations:
Users_CyberArk_Group_
The Users
property in the CyberArk_Group
entity:
- is written to the Property1 attribute of the
Entity Association element. - is filled in by values from the
MemberId
column (written to the Column2 attribute of theCyberArk_Group_Members
Entity Association Mapping element) in theC:/UsercubeDemo/Temp/ExportOutput/CyberArk_members_Groups.csv
file.
These values identify resources of type CyberArk_User
by their CyberArk_id
property (written to the EntityPropertyMapping2 attribute of the Entity Association Mapping element.
Groups_CyberArk_User_
The Groups
property in the CyberArk_User
entity:
- is written to the Property2 attribute of the
Entity Association element). - is filled in by values from the value column (written to the Column1 attribute of the
file.
These values identify resources of type CyberArk_Group
property (written to the EntityPropertyMapping1 attribute of the Entity Association Mapping element).
Display
Navigation
A Menu Item can be added to include a link to the resources list in the left menu in the UI home screen.
Parent menu item
It strongly recommended to gather synchronized resources menu items under parent menu items. This is usually declared in the configuration root folder Nav.xml
file.
Example
Conf/Nav.xml ...
Child menu item
It is strongly recommended to use a new CyberArk Nav.xml
file in the SCIMCyberArk
connector's folder in order to add the CyberArk SCIM objects menu item.
Example
Conf/SCIMCyberArk/CyberArk Nav.xml ...
<MenuItem Identifier="Nav_Connectors_CyberArk" DisplayName_L1="CyberArk" DisplayName_L2="CyberArk" ParentMenuItem="Nav_Connectors"> <MenuItem Identifier="Nav_Connectors_CyberArk_User" DisplayName_L1="CyberArk Users" DisplayName_L2="Comptes CyberArk" EntityType="CyberArk_User" /> <MenuItem Identifier="Nav_Connectors_CyberArk_Group" DisplayName_L1="CyberArk Groups" DisplayName_L2="Groupes CyberArk" EntityType="CyberArk_Group" /> <MenuItem Identifier="Nav_Connectors_CyberArk_Container" DisplayName_L1="CyberArk Safes" DisplayName_L2="Safes CyberArk" EntityType="CyberArk_Container" /></MenuItem>...
Adds a new menu item under the Nav_Connectors
menu item declared in the root Nav.xml
file. This new menu item gives access to the list of synchronized CyberArk SCIM objects.
Configuration
It is strongly recommended that the display configuration be written to a new CyberArk UI.xml
connector's folder.
Display entity type
The Display EntityType describes how a single resource should be displayed.
Example
Conf/SCIMCyberArk/CyberArk UI.xml ... <DisplayEntityType Identifier="CyberArk_User">
<Property OutputType="BasicCollection" Identifier="groups" />
<Property OutputType="BasicCollection" Identifier="containers" /></DisplayEntityType>...
This configuration configures that display for christian.adam@acme.com:
The scalar properties don't need to be configured: they are automatically displayed. The only information that the DisplayEntityType adds here, is that the property BasicCollection
is a navigation property. An eye icon will be displayed to take you directly to the matching page.
Display table
The DisplayTable elements describe how a list of resources should be displayed.
The DisplayTable contains a list of DisplayTableColumn elements that identify which properties should be included in the list display.
Example
<DisplayTable Identifier="CyberArk_User" EntityType="CyberArk_User" DisplayTableDesignElement="resourcetable" IsEntityTypeDefault="true">
<Column DefaultSortPriority="1" DisplayBinding="userName" IsDisplayInSummaryView="true" IsResizable="true" IsSortable="true" CanBeFiltered="true" ColumnSize="2" />
<Column DisplayBinding="givenName" IsDisplayInSummaryView="true" IsResizable="true" IsSortable="true" CanBeFiltered="true" ColumnSize="2" />
<Column DisplayBinding="familyName" IsDisplayInSummaryView="true" IsResizable="true" IsSortable="true" CanBeFiltered="true" ColumnSize="2" />
<Column DisplayBinding="ldapDirectory" IsDisplayInSummaryView="true" IsResizable="true" IsSortable="true" CanBeFiltered="true" ColumnSize="2" />
<Column DisplayBinding="ldapFullDN" IsDisplayInSummaryView="true" IsResizable="true" IsSortable="true" CanBeFiltered="true" ColumnSize="2" />
<Column DisplayBinding="title" IsDisplayInSummaryView="true" IsResizable="true" IsSortable="true" CanBeFiltered="true" ColumnSize="2" />
<Column DisplayBinding="active" IsDisplayInSummaryView="true" IsResizable="true" IsSortable="true" CanBeFiltered="true" ColumnSize="2" /></DisplayTable>...
configures the following list display:
Internal display name
An InternalDisplayName
can also be declared as an
Entity Type
. The InternalDisplayName
is used in several UI screens to identify a resource for the user.
With no custom InternalDisplayName
, a default value is used (instead of the first property of the identity) containing the string "name". If no such property is found, the first declared property of the entity type is used.
Example
<EntityPropertyExpression Identifier="CyberArk_User_InternalDisplayName" Expression="C#:resource:return resource.userPrincipalName ?? resource.mail ?? resource.displayName ?? resource.Id.ToString();" EntityType="CyberArk_User" Property="InternalDisplayName" />...
adds the InternalDisplayName
to the CyberArk_User entity type to be used by the UI.
Permissions
The Access Control Rule and Access Control Rule elements define AccessControlPermission for end-user profiles to read and write the connector's data (such as resources of a given entity type). It used by the UI when displaying data such as resources and available roles.
It is strongly recommended that permissions be written to a new file. For example, the administrator profile permissions can be written to the CyberArk Profile Administrator.xml
file.
Example
The following example sets permissions for the Administrator
profile.
It entitles an administrator to display CyberArk SCIM
resource and role categories from the UI.
Conf/AzureAD/AzureAD Profile Administrator.xml ...
<AccessControlRule Profile="Administrator" EntityType="ResourceType" Identifier="Administrator_ResourceTypeSelector_resourceType_CyberArk" DisplayName_L1="Administrator_ResourceTypeSelector_resourceType_CyberArk">
<Entry Permission="/Custom/Resources/CyberArk_User/View" CanExecute="true" />
<Entry Permission="/Custom/Resources/CyberArk_Group/View" CanExecute="true" />
<Entry Permission="/Custom/Resources/CyberArk_Container/View" CanExecute="true" /></AccessControlRule><AccessControlRule Profile="Administrator" EntityType="Category" Identifier="Administrator_ResourceTypeSelector_category_CyberArk" DisplayName_L1="Administrator_ResourceTypeSelector_category_CyberArk">
<Entry Permission="/Custom/Resources/CyberArk_Container/View" CanExecute="true" /></AccessControlRule>...
Jobs
Construction
This step focuses on writing a Complete
Synchronization job.
It is strongly recommended to write Jobs associated with the CyberArk
connector to the Conf/SCIMCyberArk/SCIM CyberArk Jobs.xml
file.
Components
All the job steps can be found in the Create Connector Synchro Complete scaffolding.
Example
Conf/SCIMCyberArk/SCIM CyberArk Jobs.xml ...
<CreateConnectorSynchroComplete Connector="CyberArk" DisplayName_L1="01: CyberArk - Synchronization Complete (scaffolding)" JobIdentifier="CyberArk_Synchronize_Complete_Scaffolding">
<OpenIdIdentifier Identifier="Job"/></CreateConnectorSynchroComplete>...
This job will be executed on CyberArk's connector agent.
Notice the Identifier attribute with the value Job
in the OpenIdIdentifier
tag. It refers to the ClientId
written to the appsettings.agent technical configuration. The Tasks will authenticate with the profile associated with this ClientId
in the <OpenIdClient>
xml configuration element.
Incremental synchronization can be configured with the following Create Connector Synchro Incremental.
Permissions
To complete a Job, the Agent, via the Usercube-Invoke-Job uses:
- A Profile associated with the Job itself to read/write:
UJ_Jobs
andUJ_Tasks
tables in a list of tasksUJ_JobInstances
tables in the progress report
- a Profile for each Task, to read/write
UJ_TaskInstances
tables (Progress Report) and perform other operations such as sending export files over to the Server.
Every request from Agent to Server within the execution of a Job needs to be authenticated with an OpenIdClient Connect /Secret pair, linked to a Profile.
Create a profile
Conf/Profile AgentJob.xml ...
<Profile Identifier="AgentSynchro" DisplayName_L1="Agent Synchro" />...
As the Principle of Least Privilege states, Netwrix Identity Manager (formerly Usercube)strongly recommends that you create a Profile to be used during the Synchronization jobs which will be different from the one used during the Provisioning job. This contributes to separating access rights. The same principle applied even more rigorously would make Identity Manager create one profile per Task. It isn't necessary as most Synchronization tasks require the same permissions.
Grant synchronization access rights to the profile
For an Agent to launch server-side Tasks from the Job via the Usercube-Invoke-Job, the profile linked to these tasks and used by the tool should be authorized to execute said tasks.
- Prepare-Synchronization
- Synchronization
Required permissions are:
View Tasks
/Jobs/Task/Query
Progress Report
/Jobs/JobInstance/Query
/Jobs/JobInstance/Update
/Jobs/TaskInstance/Query
/Jobs/TaskInstance/update
/Connectors/Connector/Query
/Connectors/SynchronizeSession
Granting access can be done via the Synchronization Access Control Rules scaffolding and theJob View Access Control Rules scaffolding.
The following examples (or similar) should be written to Conf/Profile AgentSychro.xml
This example entitles the administrator profile to run any synchronization job:
<SynchronizationAccessControlRules Profile="AgentSynchro"/><JobViewAccessControlRules Profile="AgentSynchro"/>...
Grant end-users permissions to run jobs from the UI
/Jobs/RunJob/Launch
This can be done via theJob Execution Access Control Rules scaffolding.
Example
Conf/Profile AgentSychro.xml ...
<JobExecutionAccessControlRules Profile="AgentProfileForSynchro"/>...
Declare usable ClientId/Secret pairs in the configuration
An Agent's Profile is associated with a ClientId/Secret
pair used by the Agent to authenticate to the Server.
Usable ClientId/Secret
pairs are written to the database from the xml configuration using the OpenIdClient xml element.
It is strongly recommended that you write the <OpenIdClient>
xml element to a new or existing OpenIdClients.xml
file in the configuration root folder.
The ClientId/Secret
pair hence created must be associated with the profile created or updated in the previous step, via the Profile attribute.
Example
The following example creates a ClientId/Secret
pair to be used by the Agent to authenticate to the Server and complete Jobs. The secret is hashed with the
Usercube-New-OpenIDSecret
tool.
Conf/OpenIdClients.xml ...
Set up the Agent to use ClientId/Secret pairs
The ClientId/Secret
pairs that the Agent may use are written to the Agent's appsettings.agent technical configuration set.
The ClientId
of such ClientId/Secret
pairs can then be used as a value in a Task OpenIdClient attribute.
Pairs written in the OpenIdClient
section may be used by Tasks.
The Job itself uses the DefaultOpenIdClient
value.
"OpenId":{
"OpenIdClients": {
"Job": "secret"
"DefaultOpenIdClient": "Job"
Job launch
With Identity Manager's scheduler
Use the Job Job attribute.
This example uses Identity Manager's scheduler to execute the
CyberArk_Synchronize_Complete_Manually
job every fifteen minutes:Conf/SCIMCyberArk/SCIM CyberArk Jobs.xml
<Job Identifier="CyberArk_Synchronize_Complete_Manually" CronTabExpression="*/15 * * * *" DisplayName_L1="01: CyberArk - Synchronization Complete (manually)" DisplayName_L2="00: CyberArk - Synchronisation Complete (manuelle)" Agent="Local"> ...
</Job>
With an external scheduler
Example
The following command can be scheduled. It executes the CyberArk_Synchronize_Complete_Manually
using the "Job/secret" authentication pair to connect to the Identity Manager Server at http://usercube.contoso.com
./identitymanager-Invoke-Job.exe -j "CyberArk_Synchronize_Complete_Manually" --api-secret secret
--api-client-id Job --api-url "http://usercube.contoso.com"
Validation
Deploy configuration
The configuration is written to the database using the Deploy Configuration Task.
Test
After execution, CyberArk SCIM Objects resources should be in the UR_Resources
table of the SQL Server database.
