How-Tos
These guides will help you configure tasks and jobs with practical step-by-step procedures.
Build Efficient Jobs
Build efficient jobs by minimizing their costs.- #### Configure Jobs Define the permissions for creating and using jobs thanks to scaffoldings.- #### Troubleshoot Connector Jobs Understand the behavior of synchronization and provisioning tasks in order to spot and fix errors.- #### Configure an Incremental Job Configure the relevant tasks to make a job incremental.- #### Set up Complete Synchronization Build the job that will synchronize the appropriate connectors in complete mode.- #### Set Up Incremental Synchronization Build the job that will synchronize the appropriate connectors in incremental mode.- #### Configure the Fulfill Task for a Connector Create the adequate configuration to add the fulfill task of a given system (here LDAP) in a job.
