RSA Encryption
Usercube provides a few options to protect sensitive data via RSA encryption.
Sensitive data can be RSA encrypted by using Usercube's tools:
Once encrypted, sensitive values can be added to the appsettings.encrypted.json file. Usercube will read first the values from the encrypted appsettings file, before reading those from the usual non-encrypted appsettings file.
These methods require an X.509 public key certificate (the same for the encrypted appsettings file and the tools).
The value encryption tool can be used to encrypt specific values to be added to the encrypted appsettings file without having to encrypt the whole file again.
Focus on the Encrypted Appsettings File
The appsettings.encrypted.json file contains the appsettings.json file's sensitive setting values which are protected by RSA encryption.
This file follows the exact same structure as the server's configuration files.
Read the Encrypted File
Usercube can use an RSA decoding algorithm fed by a public-key certificate in order to read the encrypted application settings.
This requires the usual appsettings file(s) to have UseEncryptedAppsettings set to true. See below.
appsettings.json and/or appsettings.agent.json
"EncryptionCertificate": {
"File": "./identitymanager.pfx",
"Password": "secret",
"UseEncryptedAppsettings": true
This way, values from the encrypted file take priority over the values from the non-encrypted appsettings files.
For example, if Password exists in both the encrypted file and the non-encrypted file, then the value from the encrypted file is used.
