Application Settings
This section describes the settings available in the server's appsettings.json
file, located in
the server's working directory or in environment variables.
JSON files can contain any additional information that you might find useful. See the example below.
For example, in order to store the agent's address, we can add:
appsettings.json
"UsercubeAgent": {
"Url": "http://localhost:1234"
}As Usercube does not know any object named
UsercubeAgent
, its content will be ignored, but it can still be used to store information for human use.
The appsettings
set allows the following attributes and sections:
Name | Details |
ApplicationUri required | Type String Description URI of the server to use in log messages, to communicate with the server in tasks, to allow certain redirect URIs. Note: must be the same as the agent's appsettings.json 's ApplicationUri . Exampleappsettings.json { � "ApplicationUri": "usercubeserver.contoso.com:5000" } |
EncryptionCertificate required | Type [EncryptionCertificate] Description Settings to configure the encryption of specific files. |
License required | Type String Description License key of the server. Exampleappsettings.json { � "License": "{"LicensedTo":"Demo","ValidTo":"20120905","IdentityQuota":"10000","Signature":"�"}" } |
Agents optional | Type Agent List Description List of agents' settings used to work on several environments. Info: this way, each agent's URI/URL is configured without altering the database. Exampleappsettings.json { � "Agents": { "Local": { "Uri": "http://localhost:5010" }, � } } |
AppDisplay optional | Type AppDisplay Description Settings to override the application display XML configuration. Info: useful to change the application's theme and name without redeploying the whole configuration. |
ApplicationInsights optional | Type ApplicationInsights Description Settings to plug to and configure the AppInsights monitoring tool. |
DataProtection optional | Type DataProtection Description Settings to configure the encryption used for the authentication cookies and the anti-forgery tokens. Info: data protection can be configured to share the keys between several instances of Usercube's server, for example when deployed in a cluster where the servers do not have the same machine id. |
InstallationDirectoryPath default value: Usercube-Server.exe | Type String Description Path of the installation directory. Info: used to read other configuration files. Exampleappsettings.json { � "InstallationDirectoryPath": "C://identitymanagerContoso/Runtime" } |
MailSettings optional | Type MailSettings Description Settings to configure the email service. |
NotUseAgent default value: false | Type Boolean Description True to disable the use of the agent. Exampleappsettings.json { � "NotUseAgent": true } |
OpenIdClients optional | Type OpenIdClient List Description List of hashed secrets used to override the plain-text secrets from the OpenIdClient XML configuration. Info: this way, Usercube stores only hashed secrets, for security purposes. Note: each environment must have its own secret, distinct from the others. Exampleappsettings.json { � "OpenIdClients": { "Job": { "HashedSecret": "K7gNU3sdo+OL0wNhqoVWhr3g6s1xYv72ol/pe/Unols" }, "PowerBI": { "HashedSecret": "7b8N2NWka5alDrjM7rFqf7+xqq9LIcT5jSoQ+1Ci2V0" } } } |
PowerBISettings optional | Type PowerBISettings Description Settings to configure the API used by Power BI to access Usercube data. |
Serilog optional | Type Serilog Description Settings to configure the logging service, complying to the Logger properties and structure. Exampleappsettings.json { � "Serilog": { "WriteTo": [ "Console" ], "MinimumLevel": { "Default": "Error", "Override": { "Usercube": "Information" } } } } |
Swagger optional | Type Swagger Description Enabling Swagger enables visualizing and interacting with the API's resources without having any of the implementation logic in place. Info: it is automatically generated from Usercube's API, with the visual documentation making it easy for back-end implementation and client-side consumption. |
TempFolderPath default value: ../Temp | Type String Description Path to the temporary folder which contains: - ExportOutput : directory storing data exported from connectors. - JobLogs : directory storing task instance logs. - Reports : directory storing generated reports. - Packages : directory storing the downloaded package logos. - PolicySimulations : directory storing the files generated by policy simulations. - ProvisioningCache.txt : file storing the clustered provisioning cache. Note: when enabled, this file can be used to coordinate the API cache among clusters. - CorrelationCache.txt - RiskCache.txt - ExpressionCache.txt - scheduler.lock - connector.txt - container.reset.txt : file acting as a reset command for Usercube's server, i.e. any change to this file triggers the reset service, thus reloading all the services instantiated by the server. Note: this path can be overridden by ResetSettings > FilepathResetService. - Mails : directory storing the email messages. Note: this path can be overridden by ResetSettings > PickupDirectory. - Deployment Note: these elements can be removed, but make sure to restart the server after doing so. Exampleappsettings.json { � "TempFolderPath": "../Temp" } |
WorkFolderPath default value: ../Work | Type String Description Path of the work folder which contains: - Collect : directory storing the CSV source files exported by connectors. - ProvisioningOrders : directory storing the orders generated by the server. - FulfillPowerShell : PowerShell provisioner's working directory. - FulfillRobotFramework : Robot Framework's provisioner working directory. - ExportCookies : directory storing the cookies used for incremental export. - Synchronization : directory storing the agent's data collection results. - Upload : directory storing the uploaded media like uploaded pictures, before they are inserted into the database. - appsettings.connection.json Note: these elements must not be removed, because doing so may disrupt Usercube's execution after restarting. Exampleappsettings.json { � "WorkFolderPath": "../Work" } |
Swagger
Name | Details |
Enabled required | Type Boolean Description True to enable Swagger. Exampleappsettings.json { � "Swagger": { "Enabled": false }, } |
This information can be set one of two ways:
As a Public Key Cryptography Standards (PKCS) #12 archive (also called Personal Information Exchange file or
.pfx
file) stored in the Agent's host file system. The archive contains both the public key certificate and the private key. -
As a certificate from a Windows' certificate store identified by SubjectDistinguishedName or by Thumbprint. The Windows certificate also contains both the public key certificate and the private key.
NETWRIX recommends using Windows' certificate store.
On the other hand, the PFX file takes priority over Windows' certificate, which means that when
File
is specified then the PFX certificate is used, even if the options for Windows' certificate are specified too.In both ways, missing and/or incorrect settings trigger an error and no certificate is loaded.
As a PFX file
For example:
"EncryptionCertificate": {
"File": "C:/identitymanagerAgentContoso/contoso.pfx",
"Password": "oarjr6r9f00"
The archive is set using the following attributes:
Name | Details |
File required | Type String Description PKCS #12 archive path on the host file system. |
Password optional | Type String Description PKCS #12 archive password. |
Storing a .pfx
file password in plain text in a production environment is strongly discouraged. It
should always be encrypted using the
Usercube-Protect-CertificatePassword tool.
Name | Details |
Password optional | Type String Description PKCS #12 archive password. Info: storing a .pfx file's password in plain text in a production environment is strongly discouraged. It should always be encrypted using the Usercube-Protect-CertificatePassword.exe tool. |
As a Certificate in the Windows Store
For example:
"DistinguishedName":"UsercubeContoso",
"StoreLocation": "LocalMachine",
"StoreName": "AuthRoot"
The Windows certificate is set using these attributes:
Name | Details |
DistinguishedName optional | Type String Description SubjectDistinguishedName of the store certificate. Note: required when Thumbprint is not specified. |
Thumbprint optional | Type String Description Thumbprint of the store certificate. Note: required when DistinguishedName is not specified. |
StoreLocation required | Type String Description Location of the relevant Windows certificate store: LocalMachine or CurrentUser . |
StoreName required | Type String Description Name of the relevant Windows certificate store. |
Using Azure Key Vault
If the certificate is saved in Azure Key Vault, we must define the certificate identifier and the Vault connection.
"CertificateAzureKeyVault": "<CertificateIdentifier>"
Disabling file encryption
The encryption of specific files can be disabled via the following attribute:
Name | Details |
EncryptFile default value: true | Type Boolean Description True to encrypt specific files such as logs or temporary files. Exampleappsettings.json { � EncryptionCertificate": { "EncryptFile": false } } |
MailSettings
For example:
appsettings.json
"MailSettings": {
"FromAddress": "no-reply@acme.com",
"PickupDirectory": "C:/identitymanagerDemo/Temp/Mails",
"UseSpecifiedPickupDirectory": true,
"UseDefaultCredentials": false,
"SecureSocketOption": "StartTlsWhenAvailable"
Name | Details |
FromAddress required | Type String Description Email address used as sender for Usercube's emails. |
AllowedDomains optional | Type String Description List of allowed domains, separated by ; . |
CatchAllAddress optional | Type String Description Email address to be used as catchAll. |
CatchAllCCAddress optional | Type String Description Email address to be used as CC catchAll. |
Enabled default value: true | Type Boolean Description True to activate Usercube's email services. |
EnableSsl default value: false | Type Boolean DEPRECATED : EnableSsl won't be supported in the future. Please specify a SecureSocketOption instead. To keep the same behavior as EnableSsl: True , use the setting SecureSocketOption : StartTls . Description True to encrypt communication with the SMTP server. Note: to be used only when UseSpecifiedPickupDirectory is set to false . |
SecureSocketOption default value: Auto | Type String Description Specifies the encryption strategy to connect to the SMTP server. If set, this takes priority over EnableSsl . None : No SSL or TLS encryption should be used. Auto : Allow the mail service to decide which SSL or TLS options to use (default). If the server does not support SSL or TLS, then the connection will not be encrypted. SslOnConnect : The connection should use SSL or TLS encryption immediately. StartTls : Elevates the connection to use TLS encryption immediately after reading the greeting and capabilities of the server. If the server does not support the STARTTLS extension, then the connection will fail and a NotSupportedException will be thrown. StartTlsWhenAvailable : Elevates the connection to use TLS encryption immediately after reading the greeting and capabilities of the server, but only if the server supports the STARTTLS extension. Note: to be used only when UseSpecifiedPickupDirectory is set to false . |
Host optional | Type String Description Name or IP address of the host used for SMTP transactions. Note: required when UseSpecifiedPickupDirectory is set to false . |
Password optional | Type String Description Password to be used with the user name as credentials. |
PickupDirectory optional | Type String Description Path of the folder where Usercube will save the email messages. Note: useful and required when UseSpecifiedPickupDirectory is set to true . |
Port optional | Type String Description Port used for SMTP transactions. Note: required when Host is defined. |
UseDefaultCredentials default value: false | Type Boolean Description True to use in requests the default credentials instead of those from UserName and Password here. |
UserName optional | Type String Description User name to be used with the user name as credentials. |
UseSpecifiedPickupDirectory default value: false | Type Boolean Description True to save email messages to the folder specified in PickupDirectory instead of sending them to their recipients through the host specified in Host . Note: required when Host is not defined. |
ApplicationInsights
For example:
appsettings.json
"ApplicationInsights": {
"InstrumentationKey": "<AppInsights instance's key>"
Name | Details |
InstrumentationKey default value: null | Type String Description Key linked to the AppInsights instance to which the server's logs, requests, dependencies and performance are to be sent. See Microsoft's documentation to create an instrumentation key. |
The logs sent to AppInsights are configured through the Logger properties.
PowerBISettings
For example:
appsettings.json
"PowerBISettings": {
"PageSize": 500
Name | Details |
PageSize default value: 1000 | Type Int32 Description Size of the page containing the data returned by the API. |
DataProtection
For example:
appsettings.json
"DataProtection": {
"KeysPath": "/home/DataProtection",
"X509KeyFilePath": "../identitymanager.pfx",
"X509KeyFilePassword": "secret"
Name | Details |
KeysPath default value: ../Work/DataProtection | Type String Description Path of the location where the keys' descriptions are stored. |
X509KeyFilePath optional | Type String Description Path of the custom certificate used to protect the keys. |
X509KeyFilePassword optional | Type String Description Password of the custom certificate used to protect the keys. |
AppDisplay
For example:
appsettings.json
"AppDisplay": {
"PrimaryColor": "#01CDE9",
"SecondaryColor": "#EA6E1A",
"BannerColor": "#EA6E1A",
"BannerTextColor": "#ffffff",
"ApplicationNamePrefix": "QA - ",
"ApplicationName": "USERCUBE"
Name | Details |
ApplicationName optional | Type String Description Name of the application, visible on the application's tabs. |
ApplicationNamePrefix optional | Type String Description Prefix to be displayed before the application name. |
BannerColor optional | Type String Description HEX code of the color for the banner, i.e. the header displaying logo and navigation bar. |
BannerTextColor optional | Type String Description HEX code of the color for the banner's text. |
PrimaryColor optional | Type String Description HEX code of the color for the highlighted buttons. |
SecondaryColor optional | Type String Description HEX code of the color for the background of the authentication screen. |
