Azure Key Vault
Prerequisites
First, NETWRIX recommends reading:
Compatible Settings
Every key from appsettings.agent.json that has a string value can be saved as a secret into Azure Key Vault.
See examples in connectors' credential protection sections.
Write Settings to the Vault
After creating the Azure Key Vault, open its page on Azure's portal and add a secret.
The important part of adding a secret in Azure Key Vault is defining its name and value:
  • as secrets' names can only contain alphanumeric characters and double dashes (--) as separator, the keys from the appsettings.agent.json file must contain only alphanumeric characters too;
  • secrets' values are simply the value associated with the key in the JSON file.
For example, for the Active Directory:
appsettings.agent.json { ... "Connections": { ... "ADExport": { "Servers": [ > { > "Server": >
"paris.contoso.com", > "BaseDN": "DC=paris,DC=com" > }, > { > "Server": "marseille.contoso.com", >
> "BaseDN": "DC=defense,DC=marseille,DC=com" > } > ], "AuthType": "Basic", "Login": "login123",
> "Password": "password123", "Filter": "(objectclass=\*)", "EnableSSL": "false", } } }
To save the login to Azure Key Vault, create a secret whose name and value are respectively Connections--ADExport--Login and login123.
To save the second server, create a secret whose name and value are respectively Connections--ADExport--Servers--1--Server and marseille.contoso.com. Note that the index of the first element is 0.
This way, values from the Azure Key Vault take priority over the values from the appsettings files.
For example, if Login exists in both Azure Key Vault and appsettings.agent.json, then the value from Azure Key Vault is used.
Configure Usercube
Connect Usercube to Azure Key Vault by adding to the agent's appsettings.json file a specific section.
For example:
appsettings.json
{ ... "AzureKeyVault": { "Vault" : "https://identitymanagerkeyvault.vault.azure.net/",
"ConnectionString":
"RunAs=App;AppId={dcb9b3a4-159c-45d8-93d5-8d6d677de4a7};TenantId={7a06f56c-47a8-469b-b0c0-089ec0666bd1};AppKey={Ju4m3BWA_U~s9XVlI_btgydJ8w5wY.iD.L}"
NameDetails
Vault requiredType String Description DNS Name found on the page of the vault in Azure's portal. Info: usually in the format https://yourVault.vault.azure.net/.
ConnectionString default value: nullType String Description Identification token used to retrieve the various connection keys found in the Azure Key Vault. It concatenates a series of options defining the authentication to Azure Key Vault. null - the connection is established with the current user. Warning: this user must be connected to the Microsoft Entra ID (formerly Microsoft Azure AD) instance and to the correct tenant. Otherwise, Usercube gets the token from Microsoft Entra ID via: RunAs=App - a managed identity. Warning: connecting via a managed identity must be enabled on Azure's App Service. RunAs=App;AppId={ClientId of user-assigned identity} - a user-assigned identity. RunAs=App;AppId={TestAppId};KeyVaultCertificateSecretIdentifier={KeyVaultCertificateSecretIdentifier} - the application and a certificate's secret, for custom services authentication. RunAs=App;AppId={AppId};TenantId={TenantId};CertificateThumbprint={Thumbprint};CertificateStoreLocation={LocalMachine or CurrentUser} - a certificate with a thumbprint on TenantId. RunAs=App;AppId={AppId};TenantId={TenantId};CertificateSubjectName={Subject};CertificateStoreLocation={LocalMachine or CurrentUser} - a certificate with a DN on TenantId. RunAs=App;AppId={AppId};TenantId={TenantId};AppKey={ClientSecret} - a secret.
