Usercube-Protect-X509JsonValue
This tool is used to encrypt sensitive connection data, for example data from the
appsettings.agent.json
file, with
RSA encryption.
The encryption is based on the information given in your appsettings.json
file about either a PFX
file or the location of the
encryption certificate
in the Microsoft store.
This tool Usercube-Protect-X509JsonValue
is used to encrypt only given values, in comparison to
the
Usercube-Protect-X509JsonFile
tool that encrypts a whole file. This tool is more appropriate than Usercube-Protect-X509JsonFile
when you have only a few lines to encrypt.
Examples
The command below encrypts the task agent configuration 0
and the OpenId Client secret
used in
the appsettings.agent.json
file.
./identitymanager-Protect-X509JsonValue.exe --values "0" "secret"
As a response, the powershell returns one string per given value.
PS C:/identitymanagerTraining/Runtime> ./identitymanager-Protect-X509JsonValue.exe --values "0" "secret"
kxABACJhXxJwnGJSug/nE6ODGGYwnzhX1WeYUHmS7gkMLpF15K7POOZAVWsl93zuYaVStPK0sV+U6mOE4h5IzbT083Uac+/NKic+qNZLYi4PRum+G17pIeSMBu3z7GQJxGGkAeX7dwf0kc/oDW5yAQ1BtFN+k27UHZkUrz0fe/eOZwTHbgV5sSUM+6pXW6IQd2VnVRRKLyWij0MAKsCNlHtv6QE73b8P8u7liRdzWOueqE2blAZk0rm0JzFxZlUQKgIMBTk2cuFWph7rp8dp8h8mDKJl9xbYzAtmM/rgXuhcMYryIrlqFeBWt1J65cfL7HNQb6OX7Imb2LQZmZMI2xc1gFyiXjeINeMriYm3zecnSBMiYEGW6RddE6doJOtrTyznrg==
kxABAJT+2u1C1r0JI8criUz15QkI71x6/BPeNMlPWEL5ZHkTvZWVnMLG/zNJz9PvnjfecROC4fkxPRI5U+sF8W1caH8DtxnzM0ctYD0QtRcpS9z48y2mUzOzl3pU68BQyosyZGZW0ifXVI9UJVGMzMTfWloCw+R+xfZHviYLVGT8y2PKkCBdNp7IcZN4qT6mq8AmTIMSgwagR854n1EHn8lT5nUUFmhZ7iIJ/sonEVG4uyTAjND9YXSsfL9dm2ipTzXrybruIkVU051aczdohreMRsfeSB6TDAYa3GEMNeAb3CzI5I/6NpKYEzZEoYu4JXAzE6bqHeK2oVJyrmTL11kwq4m9fTMwlwmB0GaPeJtbQoih6TIX2qlOPfQdsrZt0dl5qw==
Then you just need to copy and paste them.
The following example shows how to update the OpenId ClientSecret matching the "ContosoCharlotte"
OpenId ClientId in the appsettings.encrypted.agent.json
file.
The initial appsettings.encrypted.agent.json
file resembles the following:
appsettings.encrypted.agent.json before update
"OpenId": {
"OpenIdClients": {
"ContosoCharlotte": "dKIHkloXG6i1LkxkhjkKoVKS9gFO7Hx8VUm"
The new ClientSecret to encrypt is charlotte2028.
Using the Usercube-Protect-X509JsonValue.exe
./identitymanager-Protect-X509JsonValue.exe --values charlotte2028
The --values
parameter also accepts multiple white-space-separated values for encryption.
The output, in the console, shows the encrypted value for the charlotte2028 string.
kxABABJR7wYaQIqNjHT/rhYVMp5Vmsao7/eBLb7JCIiHMOKbi2sC0dY0SAJgj50NQ0kEH5LS3Y3TYso98+IdnxAzpURrtNu/LUWCJo1kTLM/taygebc0MK4XbkFmWzEgzLcVhAIy8GyFgEWqgNhOx7vwSPXFRrhQTVqIjwO0QNqxlZ5s6uyQm5fk9es2o6aLL0xwbvqspReFxZwuHrguAoIvkBnaKSsDfTLSuheP6VN7yOglLHvZ8Sn9R42M2BpG/dKIHXG6i1LkxkKoVKS9gFO7Hx8VUmYgxG+qIKTRVHdpMctqWKNUJTsQkmRKs+S3qiA2mgK/iC/dp923TfigAnBLWtyXw8eKDJjZ+s6n878BIf55iEjpgOrbm5FLzj8dfqPhQw==
The last step is to update the appsettings.encrypted.agent.json
file by copy/pasting this new
encrypted value to replace the old one. It results in:
appsettings.encrypted.agent.json after update
"OpenId": {
"OpenIdClients": {
"ContosoCharlotte": "kxABABJR7wYaQIqNjHT/rhYVMp5Vmsao7/eBLb7JCIiHMOKbi2sC0dY0SAJgj50NQ0kEH5LS3Y3TYso98+IdnxAzpURrtNu/LUWCJo1kTLM/taygebc0MK4XbkFmWzEgzLcVhAIy8GyFgEWqgNhOx7vwSPXFRrhQTVqIjwO0QNqxlZ5s6uyQm5fk9es2o6aLL0xwbvqspReFxZwuHrguAoIvkBnaKSsDfTLSuheP6VN7yOglLHvZ8Sn9R42M2BpG/dKIHXG6i1LkxkKoVKS9gFO7Hx8VUmYgxG+qIKTRVHdpMctqWKNUJTsQkmRKs+S3qiA2mgK/iC/dp923TfigAnBLWtyXw8eKDJjZ+s6n878BIf55iEjpgOrbm5FLzj8dfqPhQw=="
Arguments
Name | Details |
--values required | Type String Description List of values to encrypt. |
