Usercube-Generate-Configuration
Generates from a CSV file the configuration of a connector with these entities.
Two subcommands are possible for generation.
  • simpleconnector
  • complexconnector
The simple connector allows you to generate the configuration for a CSV file and create the connector. The complex connector allows you to generate the configuration for a list of CSV files and create the connector.
1. Simple connector
From a CSV file, generates the configuration of the entity representing the CSV file.
The subcommand simpleconnector must precede the arguments.
2. Complex connector
From a list of CSV files, generates the configuration of the entities representing each file. The complex connector requires as an argument an xml file containing all the CSV files to be processed as well as the primary keys of these files.
Example of xml file
<Connector xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Name="HR" DefaultEncoding="UTF-8" DefaultSeparator=";"> <File Path="C:/identitymanager/Sources/rh_persons.csv" /> <File Path="C:/identitymanager/Sources/rh_services.csv" /> <File Path="C:/identitymanager/Sources/rh_sites.csv" /> <File Path="C:/identitymanager/Sources/rh_Categories.csv" /> <PrimaryKey Path="C:/identitymanager/Sources/rh_persons.csv" Header="EmplyoeId" EntityTypeName="HR_Person" /> <PrimaryKey Path="C:/identitymanager/Sources/rh_services.csv" Header="Code" EntityTypeName="HR_Service" /> <PrimaryKey Path="C:/identitymanager/Sources/rh_sites.csv" Header="Code" EntityTypeName="HR_Site" /> <PrimaryKey Path="C:/identitymanager/Sources/rh_Categories.csv" Header="Code" EntityTypeName="HR_Category" /></Connector>
  • Path: CSV file path.
  • File: Name of the files to be processed.
  • PrimaryKey: Fills in the primary key of the CSV file.
  • Header: Column name in the CSV file.
  • EntityTypeName: Indicates the name of the entity to be created.
  • Name: name of the connector to be created.
The subcommand complexconnector must precede the arguments.
Examples
Simple connector
./identitymanager-Generate-Configuration.exe simpleconnector -g "C:/GeneratedFile/file" -f "C:/SourceFile/confFile.csv"
Complex connector
./identitymanager-Generate-Configuration.exe complexconnector -g "C:/GeneratedFile/file" "C:/SourceFile/confFile.xml"
Arguments
Argument NameDetails
--generated-file (-g) requiredType String Description Path to the generated file.
--csv-path (-h) optionalType String Description Path to the CSV file. Note: used only for a simple connector.
--encoding (-e) optionalType String Description Encoding of the CSV file. See the list of available encodings. Note: used only for a simple connector.
--csv-separator (-t) optionalType String Description Column separator of the CSV file. Note: used only for a simple connector.
--generated-connector (-r) optionalType String Description Name of the generated connector. Note: used only for a simple connector.
--keep-all-columns (-k) optionalType No Value Description Keeps all the columns.
--connector-description optionalType String Description XML file that describes the CSV files and their primary key columns.
--file-cert-thumbprint optionalType String Description Thumbprint of the certificate when the certificate is in the store.
--file-cert-dn optionalType String Description Subject Distinguished Name of the certificate when the certificate is in the store.
--file-cert-store-location optionalType String Description Store location of the certificate when the certificate is in the store.
--file-cert-store-name optionalType String Description Store name of the certificate when the certificate is in the store.
--file-cert-file optionalType String Description File path of the certificate when the certificate is in a PFX file.
--file-cert-password optionalType String Description Password of the certificate when the certificate is in a PFX file.
