Usercube-Fulfill-EasyVista
This executable creates, updates and archives employees in an EasyVista instance.
Examples
Connector specified
Resource types specified
Arguments
Argument NameDetails
--api-client-id requiredType String Description Login used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenID Connect ClientId/Secret pair, linked to a profile with the relevant permissions.
--api-secret requiredType String Description Password used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenID Connect ClientId/Secret pair, linked to a profile with the relevant permissions.
--api-url requiredType String Description URL of Usercube server.
--connector required if --resource-typesis not givenType String Description Id or Identifier of the resource types' connector we want to update the fulfillment state.
--resource-types required if --connectoris not givenType String List Description Id or Identifier of the resource types we want to update the fulfillment state.
--certificate-identifier optionalType String Description Unique key used to retrieve the certificate in Azure Key Vault.
--vault optionalType String Description Vault uri.
--vault-connection-string optionalType String Description Connection string to connect to Azure Key Vault.
--batch-size default value: 1000Type Int32 Description Number of provisioning orders to wait between each progress report.
--task-instance-id optionalType String Description Id of the task instance which have launch the exe in a job context (for log purposes).
