Usercube-Export-Excel
Examples
Exporting a file respecting the default parameters
Consider the file C:/identitymanagerContoso/Sources/hr_example.xlsx
with UTF8
encoding, it can be
exported using these command's arguments:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example.xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput
The output file(s) will be located in C:/identitymanagerContoso/Temp/ExportOutput/
. Their number
corresponds to the number of sheets in the XLSX file and they would be labeled: HREXAMPLE_0.csv
HREXAMPLE_1.csv
, � HREXAMPLE_n-1.csv
where n corresponds to the amount of spread sheets of the
XLSX file. The encoding is UTF8
and the separator is ,
Skipping some file's lines
The possibility to skip lines is made available using the --lines-to-skip
argument:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example.xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput --lines-to-skip 10
As a consequence, the exported file would include the content of the XLSX file without the ten first lines.
Regex in file name
Considering a generated file following the regex: C:/identitymanagerContoso/Sources/hr_example(.*?).xlsx
for instance C:/identitymanagerContoso/Sources/hr_example5fH8g1.xlsx
, if several files match with the
regex, the executable would use the most recent one.
The regex can be included in the filename and would need to be precised using the --is-regex
argument:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example(.*?).xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput --is-regex
Choosing value to trim
It's possible to precise characters to trim using the --values-to-trim
argument:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example.xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput --values-to-trim e
The CSV output file will see every words beginning and ending by "e" (lower-case, this process is case sensitive) removed of this letter.
Ignoring particular sheets
The --sheets-ignored
argument allows the user to specify for each sheet if it should be ignored
during the export. More precisely, a list of true or false arguments should be specified
respectively to the sheets. Let's say the C:/identitymanagerContoso/Sources/hr_example.xlsx
file
possesses three sheets, in order to export the first and the last ones the arguments would be:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example.xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput --sheets-ignored false true true false
Thus, two CSV files would be created corresponding to the the chosen ones: HREXAMPLE_0.csv
and
HREXAMPLE_3.csv
Path Duality and the Not-Launch-Export System
The export executable might be used for a complete or an incremental synchronization. Thus, it
possesses two paths that could be precised - depending on the case - with the --raw-files-path
for
complete synchronizations argument or the --path-incremental
for incremental ones.
At the end of the day, the --not-incremental
argument defines the export behavior: if present it
means a complete synchronization should be performed and the --raw-files-path
argument must be
precised; if missing an incremental synchronization would be performed using --path-incremental
It means that if the user provide the --not-incremental
argument and no --raw-files-path
, or if
the user doesn't provide --not-incremental
nor --path-incremental
, the export will not be
launched to prevent any issue (complete data for an incremental synchronization for instance). The
--force-complete
argument bypasses this safeguard: during the initialization job for example,
where we want to perform a complete synchronization, even for Excel connections with only an
incremental path.
Arguments
Argument Name | Details |
--not-incremental optional | Type No Value Description Specifies the synchronization mode, its presence meaning complete, its absence incremental. |
--is-regex optional | Type No Value Description The file's name is a regex so we find the last generated corresponding file. |
--connection-identifier optional | Type String Description Connector's connection identifier. The output file will have this identifier as name. |
--output-path required | Type String Description Output path for the files generated by the export. |
