Usercube-EasyVistaTicket-UpdateFulfillmentState
The use of this executable supposes a previous use of the Usercube-Fulfill-ToEasyVistaTicket executable.
Usercube-Fulfill-ToEasyVistaTicket creates tickets in an EasyVista instance: Usercube-EasyVistaTicket-UpdateFulfillmentState sets the fulfillment state of the corresponding assigned resource types in Usercube for tickets that are closed (Executed) or canceled (Error).
Examples
Connector specified
In this example, for all resource types that have a target entity type of the connector EasyVista, we set the fulfillment state of the corresponding assigned resource types.
Resource types specified
In this example, for the resource types EasyVista_NominativeUser and EasyVista_Administrator, we set the fulfillment state of the corresponding assigned resource types.
Arguments
Argument NameDetails
--api-client-id requiredType String Description Login used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenID Connect ClientId/Secret pair, linked to a profile with the relevant permissions.
--api-secret requiredType String Description Password used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenID Connect ClientId/Secret pair, linked to a profile with the relevant permissions.
--api-url requiredType String Description URL of Usercube server.
--connector required if --resource-typesis not givenType String Description Id or Identifier of the resource types' connector we want to update the fulfillment state.
--resource-types required if --connectoris not givenType String List Description Id or Identifier of the resource types we want to update the fulfillment state.
--certificate-identifier optionalType String Description Unique key used to retrieve the certificate in Azure Key Vault.
--vault optionalType String Description Vault uri.
--vault-connection-string optionalType String Description Connection string to connect to Azure Key Vault.
--batch-size default value: 1000Type Int32 Description Number of provisioning orders to wait between each progress report.
--task-instance-id optionalType String Description Id of the task instance which have launch the exe in a job context (for log purposes).
