Usercube-Decrypt-File
In Usercube, files are encrypted by default. This tool decrypts an input file to save it into an output file or an OutPutConsole that can be used in Powershell scripts or programs.
Examples
Result loaded in OutPutConsole (PowerShell Script)
The following example, used in a Powershell script, saves in the variable decryptFile
the string
obtained by decrypting the files specified by the ordersFile
variable. The decryption is made
using the agent side certificate defined in the agent's appsettings.json
$decryptFile = & ./identitymanager-Decrypt-File.exe --files $ordersFile
Arguments
Argument Name | Details |
--files (-f) required | Type String Description List of all the files to decrypt. |
--encoding (-e) default value: UTF-8 | Type String Description Encoding used for any encryption/decryption. See the list of available encodings. |
--output-path (-o) optional | Type String Description Output path to save all decrypted files. Note: used only when the result is saved in a file. |
--log-level optional | Type LogLevel Description Level of log information among: Verbose ; Debug ; Information ; Warning ; Error ; Fatal . |
