Usercube-Create-DatabaseViews
Generates entity model SQL views in the Usercube database. All views are prefixed by zz_. This tool deletes all views starting by zz_ and creates views from the entity model described in the running configuration.
For every EntityType, a matching SQL view is created from the UR_Resource table.
Example
The following example allows the user to connect to Usercube server at http://identitymanager.contoso.com, using the ClientId Job and Secret secret, to generate views for Usercube's database.
./identitymanager-Create-DatabaseViews.exe --api-secret secret --api-client-id Job --api-url "http://identitymanager.contoso.com" --log-level Debug
Arguments
Argument NameDetails
--progress-use-database optionalType String Description Update progress in the SQL database.
--progress-use-database-child-instance optionalType String Description Initiate child task instance.
--progress-use-api optionalType String Description Update progress with the API.
--api-client-id requiredType String Description Login used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenID Connect ClientId/Secret pair, linked to a profile with the relevant permissions.
--api-secret requiredType String Description Password used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenID Connect ClientId/Secret pair, linked to a profile with the relevant permissions.
--api-url requiredType String Description URL of Usercube server.
You can explore created views in the Usercube database's Views folder in SQL Server Management Studio
SSMS Views
