Usercube-Configuration-Transform
This tool applies a series of transformations specified in a JSON file, on the content of a given directory.
Example
The following example searches all occurrences of Directory_User in the files inside C:/identitymanagerDemo/Conf whose names:
  • contain guest to replace all occurrences with Directory_Guest;
  • contain bot to replace all occurrences with Directory_Bot.
The resulting files are saved in C:/identitymanagerDemo/ConfTransformed.
./identitymanager-Configuration-Transform.exe --input "C:/identitymanagerDemo/Conf" --output "C:/identitymanagerDemo/ConfTransformed" --transformation-file "C:/identitymanagerDemo/transformations.json"
"*guest*": {
"Directory_User": "Directory_Guest"
"*bot*": {
"Directory_User": "Directory_Bot"
Arguments
Argument NameDetails
--input requiredType String Description Path of the directory on which the transformations are to be applied.
--transformation-file requiredType String Description Path of the JSON file that contains the transformations to be applied. The first half of the following JSON transformation file intends to search all files in the input directory whose names are filename (case-insensitively). In those files, any occurrence of ToBeReplaced (case-sensitively) is replaced with Replacement. { "filename": { "ToBeReplaced": "Replacement" }, "partialfilename*": { "ToBeReplaced2": "Replacement2" } } Note: instead of a specific file name, Usercube can search for files whose names contain a specific string, using the character *.
--output requiredType String Description Path of the folder where the result will be saved.
