Oracle Database
Export data from an Oracle database.
Package CharacteristicsValue
Display NameDatabase/Oracle
IdentifierUsercube.SQL.Oracle@0000001
ExportUsercube-Export-Sql.dll
FulfillNONE
Has Incremental ModeFalse
PublisherUsercube
ProviderClassFullNameOracle.ManagedDataAccess.Client.OracleClientFactory
ProviderDllNameOracle.ManagedDataAccess.Core
For this package, the default isolation level is ReadCommitted.
To use this package, Oracle.ManagedDataAccess.Core needs to be downloaded from the Oracle website (selecting the ODP.NET release) and copied to the Runtime folder.
NOTE: The DLL in the "Oracle.ManagedDataAccess" package isn't compatible with .NET 8
