Provision Salesforce Users' Profiles via SCIM
This guide shows how to provision a user's account profile in a Salesforce system with the SCIM connector.
Prerequisites
This guide supposes that you already have a working synchronization for Salesforce users' accounts, entitlements and links between accounts and entitlements.
Context
In Salesforce, both profiles
and permission sets
are in the Entitlements
entity, whereas they
are not managed the same way: a user account must have a profile and only one, while it can have
zero to several permission sets.
This implies a difference of treatment based on the entitlement's type
Configuration
In order to handle this special case, Usercube expects, for now, a very precise configuration. A generic configuration element will come soon to be able to customize and apply this special treatment in other cases.
For now, for your EntityType
representing Salesforce's Entitlements
entity type, you need to
have an entity property with exactly type
as identifier:
<Property Identifier="type" DisplayName_L1="Type" TargetColumnIndex="13" Type="String" />
And to map it in the Entitlements
entity type mapping:
<Property Identifier="type" ConnectionColumn="type" />
That is all you need to do. With the next synchronization, all the entitlements will have their
type
and then the special treatment can be done for those with the Profile
type when
provisioning users' entitlements.
