6.Probable Owner > FS_ProbableOwner Job
The 6.Probable Owner Job Group is designed to report on probable owners of resources from targeted file servers.
The 6.Probable Owner Job Group is comprised of:
- FS_ProbableOwner Job – Designed to report on probable owners of resources from targeted file servers
Analysis Tasks for the FS_ProbableOwner Job
View the analysis tasks by navigating to the FileSystem > 6.Probable Owner > FS_ProbableOwner > Configure node and select Analysis.
Don't modify or deselect the first and third selected analysis tasks. The analysis tasks are preconfigured for this job.
- Create Functions – Creates functions in tier 1 SQL database that are required to calculate Probable Owners
- Identify Probable Owners – Creates the SA_FS_ProbableOwner_Details table accessible under the
job’s Results node
- Set to “Start listing ownership at the root share” which is
@minlevelparameter set to Value0. - Set to “List ownership as deep into the folder hierarchy as the root share” which is
@maxlevelparameter set to Value0. - Value0 = root share, Value1 = 1 folder deep, Value2 = 2 folders deep, etc.
- Set the variable #FILTERED_TRUSTEES to a CSV file that contains one row for each SID to be excluded. When you run the job, it excludes SIDs specified in the #FILTERED_TRUSTEES variable from the analysis and doesn't report them as probable owners.
- See the Configure the Customizable Parameters in an Analysis Task topic for additional information.
- Identify Folders with no Owner Found – Creates the SA_FS_ProbableOwner_NoOwnerFound table accessible under the job’s Results node
In addition to the tables and views created by the analysis tasks, the FS_ProbableOwner Job produces the following pre-configured report:
| Probable Share Owners (A.K.A. Probable Owners) | This report identifies the number of shares owned by individuals, as determined by a weighted average of ownership of content, management, and level of activity. The top 2 owners per ownership criteria per share are displayed. | None | This report is comprised of one element:
