AD_CertificateAudit Job
The AD_CertificateAudit job provides details on access rights to the Certificate Authority.
Analysis Tasks for the AD_CertificateAudit Job
Navigate to the Active Directory > 7.Certificate Authority > AD_CertificateAudit > Configure node and select Analysis to view the analysis tasks.
- Certificate Authorities – Summarizes the Certificate Authority configuration. Creates the SA_AD_CertificateAudit_Authorites view accessible under the job’s Results node.
- Certificate Authority Rights – Provides permissions on the Certificate Authority. Creates the SA_AD_CertificateAudit_CARights table accessible under the job’s Results node.
In addition to the tables and views created by the analysis tasks, the AD_CertificateAudit job produces the following pre-configured report:
| Certificate Authority Configuration | This report helps identify Certificate Authority configuration risks associated with permissions applied on the Active Directory object level as well as other unintended configurations set on the Certificate Authority level. Additionally, limit the rights on a Certificate Authority to those needed to administer or manage it, and review the ManageCA and ManageCertificate rights for potential misconfiguration. | None | This report is comprised of three elements:
