5.Open Access > AD_OpenAccess Job
The AD_OpenAccess Job reports on all Active Directory permissions granting open access within the targeted domains. Open Access can be defined as access granted to security principals such as: Domain Users, Authenticated Users, and Everyone.
The AD_OpenAccess Job is located in the 5.Open Access Job Group.
Analysis Tasks for the AD_OpenAccess Job
Navigate to the Active Directory Permissions Analyzer > 5.Open Access > AD_OpenAccess > Configure node and select Analysis to view the analysis tasks.
- Determine open access – Creates the SA_AD_OpenAccess_Details table accessible under the job’s Results node
- Summarize open access by domain – Creates an interim processing table in the database for use by downstream analysis and report generation
In addition to the tables and views created by the analysis tasks, the AD_OpenAccess Job produces the following pre-configured report.
| Open Access by Domain | This report highlights instances of open access on AD objects, and summarizes open access by domain. | None | This report is comprised of three elements:
