6.Broken Inheritance > AD_BrokenInheritance Job
The AD_BrokenInheritance Job reports on all locations within Active Directory where inheritance is broken within the targeted domains.
The AD_BrokenInheritance Job is located in the 6.Broken Inheritance Job Group.
Analysis Tasks for the AD_BrokenInheritance Job
Navigate to the Active Directory Permissions Analyzer > 6.BrokenInheritance > AD_BrokenInheritance > Configure node and select Analysis to view the analysis tasks.
- Broken Inheritance Details – Creates the SA_AD_BrokenInheritance_Details table accessible under the job’s Results node
- Broken Inheritance Summary – Creates an interim processing table in the database for use by downstream analysis and report generation
In addition to the tables and views created by the analysis tasks, the AD_BrokenInheritance Job produces the following pre-configured report.
| Broken Inheritance by Domain | This report highlights instances of broken inheritance on Active Directory objects. This information is summarized by domain. | None | This report is comprised of three elements:
