General Tab
The General tab is for changing the job name and description.
The following options are available:
- Job Name
- Description
- Log Level – Indicates the job log level, which you can inherit from the global Settings > Application log level or customize here. See the following Log Level section for additional information.
- Write CSV Files To Job Output Directory – Exports the native data table created by a query to a CSV file in the job’s output directory. If there are multiple tables in the job, this option creates one file per table.
- Timeout [value] minutes – Job’s thread timeout value
- Command – lets you enter a command that runs from the command line upon job completion
Log Level
The log level feature includes the following options:
Use global setting – use the Application log level feature, configured at the global level.
noteBy selecting the another option from the dropdown list, you break inheritance for this job.
Debug – Records everything that happens during job execution, most verbose level of logging
- Records all Info level information
- Records everything else that happens
- Creates the largest file
Info – Records information about what stage the job is in when errors or warnings occur
- Records all Warning level information
- Records job progress information
Warning – Records all warnings which occur during job execution
- Records all Error level information
- Records all warnings and the time of occurrence
Error – Records all errors which occur during job execution
- Records job start time
- Records errors and the time of occurrence
- Records job completion time
You can switch between log levels. All the levels, including the one that you choose, shall be set for messaging in the application.
For example, this is where you set the messaging for Info, Warning, or Error at a job level.
